Rotors
Old Apr 16, 2009 | 02:29 PM
andoll83's Avatar
Rotors
Installed rotors from AutoZone a few weeks ago, and they're already pulsating... I have to find the receipt, but I can't drive my car to return the rotors because I can't drive without rotors!
Ugh
Old Apr 20, 2009 | 08:53 AM
rnorth6920's Avatar
I had the pulsating issue a few times. While under warranty, I had them turned. After warranty I put rotors from autozone with ceramic pads. Have been fine since (going on 10 months).
Old Apr 20, 2009 | 10:18 AM
imagepower's Avatar
I had same issue and went with autozone rotors and a non-ceramic pad. Did the swap-out last October and have had no issues at all.
Old Apr 20, 2009 | 10:38 AM
tireman1554's Avatar
Very happy with my AutoZone Rotors and ceramic pads. My car stops better than ever and not as much brake dust.
Old Apr 20, 2009 | 04:38 PM
Czechman's Avatar
It's always a good idea to check run-out in new rotors before installing them. It's not at all uncommon for them to need a little shave.
Old Apr 20, 2009 | 06:35 PM
HHROwner's Avatar
My mom and dad's HHR has this same issue and was able to get it serviced under warranty too. So I would assume this is a common issue seeing the number of posts I've seen about this.
Old Apr 21, 2009 | 11:21 AM
Try going back to the store and explain your problem - see if they will front you a replacement pair of rotors to install, and then you take your problem rotors back. Offer to give them a deposit (core-charge if you will) to be returned when you bring the old rotors back in. You can even offer to take them for a test drive to exhibit the problem for them. Give it a try, it just might work ok.
The other alternative, is to buy a second set, and after a few weeks, return your problem ones for a refund. I prefer the first one.
bluedograbbit2
Aug 5, 2015 05:17 PM
KingMaddog
26
Jan 29, 2012 08:27 PM
ufvj217
Jan 27, 2011 09:31 AM
robbie524
40
Nov 28, 2010 01:10 AM
voigtsga
12
Oct 7, 2010 01:17 AM
