Seizure=Totally Dead
Old Feb 27, 2011 | 03:41 PM
Jeda13's Avatar
Today I jumped in and turned the key and I thought that my car was having an electrical epileptic seizure! Lights flashing like crazy. Couple tries and all I got was a flashing engine and a flashing security, then nothing at all. Tried jumping it, got no response. GM roadside is coming in the morning to pick it up. Any thoughts? Car has 20K on it, was driven a few days ago to the dealer to get the leaky rim fixed. Maybe they put a Gremlin in?
JIm
Old Feb 27, 2011 | 03:57 PM
The security system might have triggered on you, why, its hard to tell. You can give the following a try to reset the security system, if it works you're good, if not you already have a pickup scheduled. Good luck and keep us posted.
Step 1: Insert key and turn to on. (Not start) The security warning light will be on.
Leave in this condition for 10 min, or until light goes out.
Turn key off
Step 2: Turn to on (not start) the security warning light will be on.
Leave in this condition for 10 min or until light goes out.
Turn Key off
Step 3: Turn to on (not start) the security warning light will be on.
Leave in this condition for 10 min or until the light goes out.
Turn Key off
Step 4: Car will start
No guarantees this will work, but it was posted by a GM tech on the other HHR forum and folks reported that it got them up and running again.
Old Feb 27, 2011 | 03:59 PM
urbexHHR's Avatar
Either that, or by that time your battery will be dead!!!
Old Feb 28, 2011 | 09:10 PM
Jeda13's Avatar
Turns out the owner's manual for Jumping a car is pretty weak. I was following directions to the T but didn't get anything. The tow truck driver said I didn't get enough ground and was able to jump her no problem.
2x I've tried this and failed, can anyone clue me in as to a better ground for the negative terminal?
Jim
No one could explain the crazy flashing lights. Anyone experienced this?
Old Feb 28, 2011 | 09:18 PM
Mrs. DLVRNIT's Avatar
Old Mar 1, 2011 | 12:17 AM
Jim
Where did the tow-tk driver hook up at ??
about the crazy lights.
Did have a bike do that once, was a battery that went bad, even the guages were going wacky..
Old Mar 1, 2011 | 06:45 PM
Laco's Avatar
Find something on the engine block for the ground. I've connected my charger using the block for ground instead of the strut with success, though I have not had to jump start it.
Old Mar 1, 2011 | 09:01 PM
mongo's Avatar
JIm
Wow, and I thought getting a 13hp generator in there was good...
Old Mar 1, 2011 | 09:35 PM
bk94si's Avatar
could be something as simple as a loose battery cable.
tcstoy
Dec 14, 2011 12:08 AM
nacademus
Jun 1, 2011 09:51 AM
masterchief1112
Fuel Economy - Hypermiling
18
Sep 2, 2010 08:28 AM
hzl6cm
Jun 1, 2010 06:23 AM
Scotty1979
Apr 4, 2008 05:30 PM
