Serpentine Belt
Old 02-25-2011, 08:16 AM
  #31
geg
geg's Avatar
Originally Posted by db/sb
It drives your water pump, altenator, and air conditioning compressor.
Originally Posted by Don06
It doesn't drive the water pump.
alternator stopped - no problem, the engine can run without him. Once I went 2 days without a battery. I start the engine pushing the car with my hands.
Air conditioner does not work - no problem too. Just a little sweat. Russian cars do not have air conditioning. Was not there before, not now. Heater - it is very important.
Even if the water pump does not work - it's only half the sorrow. The coolant can circulate independently. Obeys the laws of physics. The main thing - to closely monitor a temperature sensor. Avoid overheating. Slowly, but you can easily go to the service center.
Oil pump - a big problem.
Correct me if I'm wrong. HHR Serpentine belt rotates pulley of the oil pump.
geg is offline
Old 02-25-2011, 11:07 AM
  #32
geg
geg's Avatar
simply the first idea entails second thought
there is no reason for surprise
this process - the main value of communication on the forum. Of course not unique, but significant value.
Otherwise - just read the manual.
For example, I never really thought about the HHR serpentine belt. I read this post - I understand that is not ready for trouble. Error - should be corrected to obtain information.
the lifetime of the belt.
Today I talked to a lot of repairmen. I showed them my engine and my belt. Their conclusion - the belt is standard. Exactly the same belts are widely used GM. The lifetime of the belt - do not mileage more than 120,000 kilometers. Recommended replacement of the belt after mileage 100,000 miles = 62,305 miles.
geg is offline
Old 02-25-2011, 01:52 PM
  #33
No, I don't think so, Belt rotates Alternator, & A/C compressor.
sleeper is offline
Old 02-25-2011, 03:31 PM
  #34
bk94si's Avatar
I don't think I have ever seen a car that drove the water pump or the oil pump off the serpentine belt. That would be asking for trouble.
bk94si is offline
Old 02-25-2011, 03:54 PM
  #35
db/sb's Avatar
I could see that being a problem with the oil pump. I was generalizing when I said 'water pump' in the case of the HHR. There are many engines that drive the water pump by means of a serpentine belt. Some Chevy V8 engines come to mind as well as others, including the LS2 in my GTO.
db/sb is offline
Old 02-25-2011, 04:13 PM
  #36
Water pump, yes..... Not on the HHR though...... Oil pump? not that I know of.
Greybeard999 is offline
Old 02-25-2011, 05:05 PM
  #37
bk94si's Avatar
I sit corrected. I actually have a chevy v8 and it does have the water pump driven by the serpentine belt. doh!
bk94si is offline
Old 02-25-2011, 10:53 PM
  #38
Chevy V-8 has been spinning the water pump by belt since 1955, & 6 bangers even way before that..
IDK about the newest ones tho.
sleeper is offline
Old 02-26-2011, 07:40 AM
  #39
JoeR's Avatar
Oil pump is driven off the crank itself.
There are two chains. One drives the cams, the other the balance shafts and water pump.
JoeR is offline
Old 02-26-2011, 07:49 AM
  #40
db/sb's Avatar
I know but he specifically said 'serpentine' belts.
db/sb is offline
Quick Reply: Serpentine Belt
