Service airbag warning
Old Aug 22, 2017 | 07:24 PM
HHR2011dave's Avatar
Hi,
I have a 2011 hhr that i left the front passenger window open about 1/2
inch and there was a hard rain storm and the edge of the seat got wet .
When i started the car the warning sign came up . This is the first time
the seat got wet or the warning came up . When i came home i opened
the door and put a large fan on to dry out the seat . Hope this will
correct the problem . I've never had the AB warning come on as long as
i had the car . Has less than 60K on it.
Old Aug 22, 2017 | 09:09 PM
There is the passenger sensor in the seat and it's connector under the seat.
There is also a connector under the door trim that maybe under recall. https://my.chevrolet.com/recalls
Old Aug 23, 2017 | 09:13 AM
Well after the fan blowing on the seat all night i started the car and everything seems
normal again .No warning flashes or AB symbol . Checked for recalls with VIN and
none . Talked with my repair team and said this can happen if the seat gets wet .
Water gets into the connector and shorts the system . Thanks for your help donbrew .
esmarkey
Jan 29, 2009 02:34 PM
esmarkey
Dec 8, 2008 11:09 AM
Welwood
May 15, 2008 08:28 AM
