Service Traction light???
Old Jan 10, 2023 | 04:43 PM
Codes P0010 & P0011 & P0013 & P0014 are for malfunctioning VVT valves. They also set the Traction Control to off, the warning lights up.
Theory being; if the engine is not running right you don't need traction control.
BTW, the thread you are inquiring is from 10 years ago.
Old Jan 10, 2023 | 05:36 PM
As pointed out in post #9 the VVT solenoids should be replaced. Provided you have code P0010, it could also be a hub bearing issue, get your codes read and post them
Old Jan 10, 2023 | 06:04 PM
When I got VVT solenoid codes, the TC did not light. Perhaps that symptom is only on automatics? Or maybe it doesn't light on SS.
Old Jan 11, 2023 | 06:29 AM
Profile says 2009 model year no model id, so it could be an SS, but I doubt it.
vrg813
Aug 25, 2018 04:27 PM
Gusty Gag
Jul 23, 2018 10:13 AM
Angeldawn
Jan 8, 2015 02:14 AM
Big lions fan
Dec 7, 2013 04:12 PM
bowlerswife
Oct 19, 2013 10:45 PM
