Several Codes 🙄 and Odometer Problem
Old Jul 20, 2021 | 06:34 PM
Ok, the thread has been straightened out, thank you Donbrew.
Ronnie, the odometer is controlled by the BCM there is a fuse in the console fuse panel marked cluster, check the fuse.
then let’s explore the possibility of a bad ground wire or loose pin in the instrument panel harness.
Old Jul 22, 2021 | 05:52 PM
Ronnie's Avatar
Originally Posted by donbrew
Does the code reader pull the correct VIN?
Yes
Old Jul 22, 2021 | 05:53 PM
Ronnie's Avatar
Did you go back to whoever sold the car?
Does a code reader read the correct VIN?
Did you read the previous thread?
I guess I could move all of these post to the old thread so we don't get any more confused..
Did you go back to whoever sold the car? - he blocked me
Does a code reader read the correct VIN? - yes
Did you read the previous thread? - I did
Old Jul 22, 2021 | 06:01 PM
Ronnie's Avatar
The fuse is good!
Old Jul 22, 2021 | 06:38 PM
Have you inspected connector at the speed sensor on the transmission?
Old Jul 23, 2021 | 02:17 PM
  #26
Here’s a thread from yesteryear, perhaps this will help with your odometer problem , see post #5
https://www.chevyhhr.net/forums/prob...cluster-39360/
Old Jul 23, 2021 | 02:38 PM
  #27
I think I was ignored when I suggested that. But, I'm used to that.
Old Jul 23, 2021 | 07:46 PM
  #28
Not ignored Ronnie, back in Feb when you spoke of a thread, the subject was VVT codes and speedometer . This link I posted was about odometer problems.
  #29
Seems to be trending...
Old Jul 23, 2021 | 08:54 PM
  #30
From post #3 in this thread:
The odometer data is stored in the BCM. If the I/P or BCM was replaced without proper programming the odometer will be unreliable.
Your title should reflect true mileage and should note any changes. It is federal law that current mileage be disclosed upon sale of a car, so your DMV should have records and you may have legal recourse.
​​​​​​​And post #13 explaining the why.
