Shifter button is not pressed
Old May 14, 2012 | 12:36 AM
geg's Avatar
geg
I wrote yesterday ... But the problem is beginning to irritate me.
The point is - I'm trying to put the transmission lever into "Drive". But the button is not pressed! Once I was forced to press it in for 3 minutes. I thought that I was not going away ever.
When you press the brake pedal operates a mechanism - the sound is heard in area of transmission lever. My sound is gone! Firing is not the first time.
What is this?
Old May 14, 2012 | 12:47 AM
Hi Geg. I don't think it is a major problem - other people have had the same problem, and I don't think it is a real bad issue. There are other posts about it - I am searching for some information for you.
Old May 14, 2012 | 12:53 AM
https://www.chevyhhr.net/forums/show...ht=shift+lever
Old May 14, 2012 | 01:04 AM
geg's Avatar
geg
Thank you, Tom.
The situation begins to dawn.
Old May 14, 2012 | 01:09 AM
Sorry I cannot help more - I am using a tablet computer instead of my PC - so searching, copy/paste is a bit awkward. I hope that link gets you started on determing the problem.
Old May 14, 2012 | 03:12 AM
geg's Avatar
geg
The reason for failure - found. Problem solved.
Reason: Some time ago I forgot an opened jar of Fanta in the car. In the evening I told my son, go for it. The order was fulfilled, but he spilled soda all over the interior - I have to urgently wash through the improvised means. Unfortunately, a drops of Fanta got inside the selector and candied solenoid. Sticky solenoid! Brrrr! .. It's disgusting.
Solution: Removing the plastic of the waterfall - Search Solenoid - Solenoid lubrication by WD-40. The works by the autoelectrician. Cost of works - 400 rubles (or $ 34).
Conclusion: I have always been the enemy of food in the car, I even wrote about it in this forum. Experience has shown - the more distance between your food and your car, the more security for your wallet.
TOM - thank you again/
OregonHHR
Dec 28, 2014 12:25 PM
tntwolt
Apr 6, 2014 01:10 AM
Cajun
Jun 21, 2008 11:00 AM
mchuntley
Mar 29, 2008 12:36 PM
WickedHHRLT
Apr 13, 2007 04:19 AM
