shifter stuck/sticks
Hello,
my 2010 hhr (2.2) is doing the same thing (only in colder temps)... I have to depress the shifter button like 10times to get it into reverse (or any other gear for that matter)did you ever figure out the cause??? I talked to someone at a dealership who said it may be a solenoid going bad
They don't sell the pieces, only the entire shifter assembly. If you still have 3/36000 use it. Dealer fix is going to be around $300-$400.
anyone know what "styles" the leather boot one came in? for example..im interested in the black boot, but does the knob have a chrome stripe or is it full black? is the knob button chrome or do some come black too? etc etc
also if anyone is interested in this leather boot shifter..the partnumber for AUTO is 25995461. All other part numbers have either been replaced by this one or discontinued. So its the automatic transmission control complete assembly including leather boot (except leather shift knob)
so if anyone has the leather boot with leather knob would you be able to let us know the part number of that assembly or pm me your vin so i can shoot it over to GM and locate that exact assembly for purchase
2010 HHR 2.2 stuck in park too
I too have this problem this am .. I have yet to have all the other recalls done, hopefully this issue is covered by drive train warranty .. its 24 outside this am .. I'm assuming the cold has something to do with it .. just hear click click click .. sounds like a combo of the ignition clicking and the shifter.. and after reading several posts .. could be the brake pedal safety switch, or the shifter .. or possibly in the steering column.
Ive already had bearings replaced and the axle snapped under warranty .. now this .. .. hhr got to get rid of this POS car.. before something else falls off
Most likely the solenoid on the shifter. A shot of WD40 should do it. Not drive train, the dealer will try to sell you an entire new shifter assembly.
They probably will not be able to reproduce the problem.
Hello dzmija I am new here and my 2010 is doing the same thing today I barely touched the brake until I heard the click and stopped pressing the pedal there lo and behold it shifted it came out of park fine its 20 here in ohio today I was wondering if you press the brake pedal to far would that bypass the brake switch and prevent it from coming out of park? I am not a mechanic and was wondering about this. Hope it keeps working.
