Shut hatch with batteries out - can I use the posts up front?
Old May 19, 2015 | 01:20 PM
Basically pull the relay and bypass it with the 9V.
Old May 19, 2015 | 01:35 PM
db/sb's Avatar
You could also connect the + from your 9 volt battery to pin 14 and the - to pins 4 and 5 on your OBD port. That would provide power to open the hatch.
Old May 19, 2015 | 02:19 PM
2manyvans's Avatar
One thing I have learned here is not to doubt donbrew, I can collect them , but he can Fix them...john
Old May 19, 2015 | 03:25 PM
I think I meant pop the fuse, not the relay, then use the 9v + on the switch side. It's been a while since I looked at that.
Old May 19, 2015 | 04:21 PM
db/sb's Avatar
I'm not doubting him. I'm just suggesting another way to do it. I've been 'fixing' cars for about 50 years myself.....seldom do I send a vehicle to the stealership for repairs.
Old May 19, 2015 | 04:50 PM
Yep, and then here's another : one of those memory minder things that you plug into the 12Volt accessory outlet. Or one of those cheap "jump start" things that plug into the same outlet, I happen to have one in my car (they are 12V and cost around $10).
HUSKYSHHR
Jun 9, 2011 10:43 PM
87silver
Jun 10, 2010 10:52 AM
hyperv6
Dec 5, 2009 09:45 AM
siifly
Feb 22, 2008 07:57 PM
GDZHHR
Jun 26, 2007 11:51 PM
