So My Chk Engine light went on :)
Old Mar 20, 2014 | 12:01 AM
Britjoe's Avatar
My Codes (nothing)
Old Mar 20, 2014 | 12:17 AM
Well if you changed the battery out after the last CEL, the codes would have been cleared during the battery swap.
It gave your HHR a "lobotomy" of sorts, it's not the most precise method for correcting faults, but many an HHR has benefited from having the Negative battey cable unhooked for 5-30 minutes.
That clears out everything, and triggers the ECM's "Learn Down" mode, giving the vehicle a fresh start.
Old Mar 20, 2014 | 09:56 AM
No codes, no check engine light, new battery, no present issues then, I would run it and if, yes IF the engine light comes back on then pull the codes.
purple people eater
Sep 17, 2016 01:07 PM
Johnhern777
Apr 21, 2014 05:26 PM
flooprigger
Aug 4, 2013 08:58 AM
jmpnjoe86
Mar 10, 2013 06:13 PM
jmarines
Feb 17, 2009 11:43 PM
