SS Trans
Old Oct 23, 2011 | 11:33 AM
ATLsilverSS's Avatar
Originally Posted by 1Panel2NV
hmmm...that's surprising.
for a gms1 car with under 10k the clutch should not slip. period. if it is, then something is wrong....just as in the op's situation. if he is completely stock it shouldn't even matter what rpm he goes wot in, the clutch should hold it no matter what. on a stock tune with 95k miles i could go wot at 40mph in 5th going up a hill and my clutch won't slip. and in jonboyb's situation....why would gm make a stage kit if the stock clutch cant handle the power? and i meant if the weather is cold...not the car.....thanks for your sarcasm tho
Old Oct 23, 2011 | 03:44 PM
1Panel2NV's Avatar
Originally Posted by 10RedSS
If i am going 50mph and drop to 3rd it will slip, if i go to 4th same speed it slips, same in 5th. this is all after the car is up to temp. I always let the vehicle warm before any quick shifts or any aggressive driving. Low rpm's say 30mph in 3rd it will slip. 45 in 4th or 5th I don't even have to have full throttle for it to happen.
Originally Posted by stanvalp
a fully engaged clutch should NOT slip. if it does, its worn out or the pressure plate is not fully released.
Holy **** guys.
The clutch on lnf's can slip if THE CLUTCH is cold. I'm not talking about the ambient temperature or the engine temperature. It doesn't mean the clutch is bad despite what you may believe.
Enjoy trying to get it replaced by GM.
Old Oct 25, 2011 | 09:16 PM
10RedSS's Avatar
its all taken care of, under GM warranty.
Lethal Tendencies
Jan 21, 2013 12:30 PM
Joshua022
Drivetrain (Excluding Engine)
14
Aug 18, 2012 07:33 AM
motoretro
Nov 26, 2010 06:47 PM
Rice Reaper
Racing Discussion
Jun 9, 2010 01:45 PM
bartSS
Jul 28, 2008 07:18 PM
