Starts with rough idle then revs up
Old Aug 28, 2021 | 10:06 AM
  #151
skysailor's Avatar
Thanks! I will look for it when I get the car back from the dealership on Monday.
Old Aug 28, 2021 | 10:17 AM
  #152
https://zzperformance.com/products/zzp-1-0-2-2-2-4-pcm
Maybe contact ZZP and ask about tuning your ECM ?
Explain your situation with that 2.2 where a 2.4 should be?
Ask what is the best way to resolve the issues, is it just a matter of time and reflash with a Tech II scanner? Or is a full tune required?
Old Aug 28, 2021 | 10:55 AM
  #153
skysailor's Avatar
Thanks Oldblue. Went to their Web site and see that they are closed on weekends. I sent an email with a short explanation and asked for guidance. Appreciate the link to them and I will certainly report what I get back and where I end up going with this. Cheers
Old Aug 28, 2021 | 11:17 AM
  #154
I just checked and even the ECM is common between the 2.2 and 2.4, so it must be the program flash that is different. So possibly a 2.2 ECM installed into your HHR will let you see if it runs better, even though it’s not fully tuned to your HHR, which you don’t want because it’s not looking at a 2.4 instead the 2.2.
Old Aug 28, 2021 | 11:37 AM
  #155
Might be worth a try to jus get a 2009-2011 2.2L ECM from the local junk yard. It' just a unplug plug job.
Old Aug 28, 2021 | 12:15 PM
  #156
Check your ECM part number see if it matches any of these numbers
2010 Chevrolet HHR ECM 2.2L Engine Control Module (PCM/ECM/ECU) Plug&Play
Programmed, Flashed & Updated with the latest OEM Software Updates from the car manufacturers.
PCM ECU ECM Part Numbers That Are Compatible With This Control Unit
12594750, 12597125, 12611549, 12612397, 12618028, 12618031, 12629019, 12630186, 12635901, 12635902, 12638026, 12639669 & 12639672
Old Aug 28, 2021 | 06:22 PM
  #157
skysailor's Avatar
donbrew and Oldblue - I will pursue both of your suggestions! Thanks very much for the effort and support of providing this guidance and info. I will hopefully be able to report some progress by early next week. Light at the end of the tunnel??? Hope so! :)
Old Aug 30, 2021 | 02:39 PM
  #158
skysailor's Avatar
Response from ZZP:
Hello Michael,
Honestly, I would suggest the most direct route. In this case is getting the engine the PCM calls for. there are a few differences between the 2.2 and 2.4, so if you get an actual 2.4 that should fix everything.
Ryan Derrick
I replied with a plea for some alternate solution but have not heard back from him.
In the mean time I am waiting to hear from the dealership service manager who has opted to put me in contact with "a guy" who does tuning on a variety of cars to see if he can help me.
Oldblue: Every outfit I call regarding this will only provide me with an ECM/PCM that is programmed based upon my VIN number which just gets me another one programmed for a 2.4l engine.
Old Aug 30, 2021 | 02:42 PM
  #159
So on that theory you should be able to swap in an ECM for a 2.2? Do you have the HHR back, did you investigate those numbers for the ECM?
Old Aug 30, 2021 | 03:18 PM
  #160
skysailor's Avatar
Oldblue: Here are photos of the modules and the label on the timing chain side of the engine. Hope you can tell me something magical based on this! :)
