Starts with rough idle then revs up
Old Aug 26, 2020 | 07:35 AM
  #81
Good detective work, let us know if that resolves the issue.
Old Aug 26, 2020 | 03:03 PM
  #82
skysailor's Avatar
Well my last post was more of a question than a statement. Does anyone have any thoughts to back up my current theory before I commit to buying another part? :)
Old Aug 26, 2020 | 05:48 PM
  #83
I meant that if you replace the throttle position sensor .
Send hellshotrod a PM , he should have a known good used one . Probably let you have it for the price of shipping.
Old Aug 26, 2020 | 05:53 PM
  #84
skysailor's Avatar
Thanks Oldblue. I do understand that and appreciate your comment. Was just wondering if anyone had some encouraging words based on experience with this problem My comment was not meant as a criticism. Anyhow,
I just ordered a pedal with sensor from GM parts for about $50 shipped so we will see :) I will report back as to whether or not it resolves my problem. Cheers :)
Old Aug 26, 2020 | 06:09 PM
  #85
No problem, let us know the results
Old Aug 31, 2020 | 04:06 PM
  #86
skysailor's Avatar
Well, I am adding another good used part to my collection. The new accelerator pedal w/sensor did not resolve the issue. So I next pulled the fuse box apart to clean all the contacts in a desperate attempt and that too failed to resolve the problem. Done for the moment but I put a meter on my battery and I get 12.24 vdc. I have not had the battery load tested but could that be an issue?
Old Aug 31, 2020 | 04:33 PM
  #87
The batteries age and condition was discussed way back in April, have that battery load tested, 12.2 volts is a dead battery, a load test will verify the cold cranking amps. These trucklets require at least 12.5 volts for starting. A 4 or 5 years old battery could have a dead cell or 2 .
Old Aug 31, 2020 | 05:04 PM
  #88
skysailor's Avatar
That will be my next step before I break down and search for a dealer with my tail tucked in!! :)
Old Aug 31, 2020 | 06:44 PM
  #89
Why a dealership, go to your local parts palace, get the battery load tested.
Old Aug 31, 2020 | 09:04 PM
  #90
skysailor's Avatar
Yeah, what I meant was that after battery is confirmed or replaced via local parts/service, if I still have the problem, then I will look for a dealership :)
