Still dinging
Old Mar 7, 2020 | 04:51 PM
  #61
Toyasock's Avatar
Originally Posted by Oldblue
The switch is more likely the culprit, but do this in steps to confirm the issue is resolved.
that's what I ment the ignition switch is getting replace I will post if it solves the problem
Old Mar 7, 2020 | 07:46 PM
  #62
bailbud's Avatar
I replaced the ignition switch first but didn't solve the problem nor did the lock cylinder.
Old Mar 12, 2020 | 12:58 PM
  #63
Toyasock's Avatar
Originally Posted by bailbud
I read TFM!
I never said anything about locking the door with or without the fob .
try this go sit in your car put the key in the ignition, open the door I bet you will hear chimes. Take the key out and the chimes stop?? Mine DON'T!! Until I close the door. I'm not locking the door with or without the fob just opening and closing .
I have jiggled and wiggled the key and steeringwheel no change.
the key does not seem to be as snug in the ignition as my truck.
same problem on my 06 I'm having
Old Mar 12, 2020 | 01:21 PM
  #64
Bail bud, go through you DIC and check the auto lock is on or off.
Old Mar 12, 2020 | 02:02 PM
  #65
Bailbud
If the chimes stop when you close the door what is the problem?
If you have the headlights on auto, give this a try; turn them to off before you remove the key instead of letting them time out.
Old Mar 12, 2020 | 02:07 PM
  #66
Toyasock's Avatar
it stops but it still drains the battery that's the problem what ever is making it chime is making the battery die
Old Mar 12, 2020 | 03:03 PM
  #67
The list of things that make them chime was posted a few pages back.
If you have a Tech2 or equivalent here is the test procedure, you can probably figure out how to use a VOM to do it.
Here is a pdf of the anti-theft circuit, I would check all of the door ajar switches including the lifgate. They all switch to ground, a test light should be good.
anti-theft circuit.pdf
Old Mar 12, 2020 | 03:10 PM
  #68
bailbud's Avatar
Bailbud
I will try the headlights trick
the problem is the remote start won't work
Old Mar 12, 2020 | 03:20 PM
  #69
bailbud's Avatar
I don't recall an auto lock in the DIC it does it when shifting out of park, it quit for a bit then when I had the battery disconnected for a bit it started working again. I do have a auto unlock with shift to park or key off
Old Mar 12, 2020 | 03:22 PM
  #70
The remote start won't work if a door is ajar or not locked, that is the reason for the Lock, Lock, Start sequence. Or some hidden OBD codes or the hood ajar switch
I am not sure if the door locks send the ajar signals or if the courtesy light switches do that. Another place to look.
