Still dinging
Old Feb 17, 2020 | 01:25 PM
  #51
bailbud's Avatar
No love from GM ,was told if the lock cylinder was a faulty part it would have failed within a year. It was replaced may 12-2014 Was dinging in early 2017 when we got it . There is special coverage 14632 key stuck in ignition but don't have that issue.
guess I will be ordering a lock cylinder
Old Feb 17, 2020 | 01:56 PM
  #52
You should order it from GM with your VIN or learn how to code key cylinders.
I think what they actually meant was the replacement had a 1 year warranty.
Some dealers were doing customer satisfaction repairs before the recall and some people were buying cylinders and replacing them. The recall included part numbers from Autozone and other stores. If you order one from ebay chances are you will get New Old Stock (pre recall).
The procedure was supposed to be
1. you make an appointment
2. the dealer orders the recall kit for your VIN from the factory
3. you wait a month or so for the parts to arrive
4. have the dealer install.
If yours was indeed done very shortly after the recall announcement, I would be assuming they used parts on hand. Receipts and part numbers would be handy.
Old Feb 18, 2020 | 09:07 PM
  #53
bailbud's Avatar
Will check the part number when I get it apart.
thinking of ordering from rockauto ?
post recall parts??
Old Mar 1, 2020 | 11:41 PM
  #54
Toyasock's Avatar
Originally Posted by bailbud
it only dings with the drivers door open .
stock radio
I have an owner's manual I just keep forgetting to bring it in .
I am currently going threw same exact problems as u I have a 06 hhr lt
Old Mar 1, 2020 | 11:50 PM
  #55
Toyasock's Avatar
stock radio
[QUOTE=donbrew;883811]You have maintained that it dings all the time; now it is just when the drivers door is open.
The Owner Manual from my sig is digital; you don't need to
Old Mar 1, 2020 | 11:55 PM
  #56
Toyasock's Avatar
no it locks fine with the remote, the security light on the dash flashes, the horn chirps and the lights flash when the button is pushed twice. The chime sounds when the key is removed and the drivers door is open
yes I have 06 hhr and I been dealing with this issue for a yr i have replace battery alternator and starter just had ignition switch replace still chimes when i open door with key out of ignition
Old Mar 2, 2020 | 08:19 AM
  #57
Take it back to the dealership that did the ignition recall work.
Old Mar 3, 2020 | 08:26 PM
  #58
bailbud's Avatar
I just got my ignition lock cylinder so will be replacing it this weekend hoping it solves the problem
Old Mar 4, 2020 | 08:21 AM
  #59
The switch is more likely the culprit, but do this in steps to confirm the issue is resolved.
Old Mar 7, 2020 | 02:52 PM
  #60
bailbud's Avatar
Well I replaced the ignition lock cylinder no change .
I guess I'm back to square one.
I have been sitting in the car playing with switches and noticed that there is no different sound in the chimes with the headlights on or off or auto or on .
New development, the doors are no longer auto locking when it's put in gear however that may be a different issue.
