Stupid Question
Old Jun 8, 2019 | 09:04 AM
DrLoch's Avatar
Obviously I didn't read all the posts..... sorry.
Now my head is hurting; what does the built-in diode do when you reverse it? I guess it doesn't matter as long as it blocks the bounce in one direction.
Old Jun 8, 2019 | 12:04 PM
Cat Man HHR's Avatar
The diode is to stop back current to the pull in coil.
Yes the diode is directional.
I know it's another conspiracy. There is no diode in the circuit, only the propaganda wiring diagram to fool us.
Old Jun 8, 2019 | 01:18 PM
There is a diode on the diagram on the relay, or something that looks like a diode. on the coil side.
Old Jun 8, 2019 | 01:24 PM
Sorry the symbol for a diode looks like this:
https://learn.sparkfun.com/tutorials...d-led-polarity
That is a symbol for a fixed resistor. That's why it can be reversed and still work.
Old Jun 8, 2019 | 01:29 PM
  #26
What is this symbol? I was assuming it is a diode in "consumer".
Old Jun 8, 2019 | 01:32 PM
  #27
OK, I guess a high enough value would do the trick.
Old Jun 9, 2019 | 08:13 AM
  #28
DrLoch's Avatar
Removed
Old Jun 9, 2019 | 08:38 AM
  #29
Dr. Loch the symbol in question on the relay is for a fixed resistor. A resistor like this can allow current in either direction.
If it was a Bidirectional Diode it would show your drawing, it does not.
So what is causing this person's problem to start with ?
Old Jun 9, 2019 | 09:02 AM
  #30
DrLoch's Avatar
Removed any info, you happy now? I'm out
