Suspension Problems/noise?
Old Jan 30, 2008 | 07:35 AM
  #41
TY&HHR's Avatar
Just took mine back Monday for that problem for the forth time. Well, upon pick up the service rep went over what they did. And good news......there is a TSB out for this problem now. They have to place foam around parts in order to keep them from hitting each other and making that noise. It was gone this morning when I went to work and it was 30 degrees. So maybe it's fixed for good now.
Old Jan 30, 2008 | 11:45 AM
  #42
ke.ster's Avatar
Drivers Side Clunking Noise
They Finally fixed mine a week and a half ago with Insulating around the Sway Bar Bushing, If I understood them correctly. This was after the fifth time taking it in. My Clunking Noise could be heard and felt under the Drivers Feet when ever you hit a bump in the Road, and it got worst in cold weather. It was there since day one but I could only hear it when I turned into my Driveway. After about 10 months it got bad enough for them to hear it and I took it in. 2 months later it's finally fixed.
Old Jan 30, 2008 | 12:06 PM
  #43
Size:  7.7 KB Glad to hear that you're not hearing it anymore.
Old Jan 30, 2008 | 12:20 PM
  #44
xzombiex66's Avatar
I also took my car in and they fixed mine i was getting the noise in the front when the car was cold it sounded like i had a flat tire.They replaced my right strut,they said there was seepage around it, and now its all good. They noted that it was checked per bulletin 04-03-08-006b.
Old Jan 30, 2008 | 06:24 PM
  #45
JPALLACH's Avatar
yes i have the same cold weather noice. struts disassembled/cleaned /checked 1st winter . 2nd winter noise returned. serviced on some level (probably sliicon spray ) noise abated for a while the retunred . Struts replaced at in summer at 36k as warranty expired . 3rd winter 2008 noise returned. scheduled now for swybar link replaced . parts on backorder . whats with that ?
Old Jan 30, 2008 | 06:41 PM
  #46
-md- HHR's Avatar
Man I really need get my HHr to the dealer.
Old Feb 1, 2008 | 03:41 PM
  #47
wrusprod's Avatar
I have had the noise for awhile...not the loud spring-like sound that the struts do when its cold..
its a light thumping noise thats heard at low speeds,and when going over bumps or cracks in the road.kind of like a rattling/thump noise.
Took it to my buddies garage and put it up on the hoist..I can see where the sway bar on the front passenger side is hitting the lower A frame..
not sure of the fix for this yet..but at least I know what it is..
Old Feb 19, 2008 | 11:07 AM
  #48
volley550's Avatar
This is my second winter with my HHR and I too have had front end noise problems and several annoying trips to the dealer. Last winter they replaced a couple parts (something with the bushings) and added a rubber piece for noise reduction (sounds like a bandaid to me!). The CS Manager agreed to extend my warranty to this winter given the numerous trips. Well it has made the noise again this winter but not as bad so I never took it in. A good friend inspected my car today for the state inspection and both struts are leaking. Looks like another trip to the dealer. I should have kept my Mitsubishi. I never had it in the shop for anything but maintenance.
Old Feb 25, 2008 | 05:47 PM
  #49
Lee3333's Avatar
I have believed for a long time now that the noise I get from the rear when it is cold is the struts. My dealer said that I should leave the car with them overnight so they can hear it when it is cold (the noise goes away by the time I drive there). I have been negligent, but I have to do it. Have several other problems I want to take care of, but I just dont want to be without a car for a couple of days (even though my wife will let me use hers).
Old Feb 25, 2008 | 07:29 PM
  #50
Lone Ranger's Avatar
GM must be buying Chinese made struts.
