Svc tire monitor
Old Jul 18, 2022 | 03:21 PM
Jimm's Avatar
Svc tire monitor
Hi, My tpms light is on and Tried to reset since my winter tire do not have sensors . Tried to do by setting learn mode by pressing buttons on fob,horn sounds. I have the tool to reset sensors. Starting with drivers side the horn sounds, right front tire next, horn sounds. then back right and horn sounds, Finally drivers rear and horn sounds twice. Took for a run around the block but the stays on and DIC does not show any pressure read out. Am I missing something , any help will be appreciated.
Jim
Old Jul 18, 2022 | 03:59 PM
driver rear needs new sensor. You could test by starting Driver rear, is the same result it is dead.
The way it works is: first position set goes into the driver front slot. Doesn't matter where it actually is.
Old Jul 18, 2022 | 04:04 PM
X2 a dead battery in the sensor, you can just change the one and wait till the others die, or replace them all.
Old Jul 19, 2022 | 03:10 AM
PulpFriction's Avatar
If you got a single honk for 3 of 4 but none are showing on the dic maybe you haven’t driven it far enough yet. Odd how long it seems to take. I installed wheels/tires with dead sensors and the car continued to display the old data for at least ten miles, maybe more.
Old Jul 19, 2022 | 07:58 AM
2 honks means malfunction.
Old Jul 19, 2022 | 08:04 AM
Jim, I see you have a 2008 HHR, perhaps the RCDLR is in need of a reprogramming? But it’s still very plausible you’re sensor has a dead battery.
Old Jul 19, 2022 | 11:49 PM
Yeah, been there, but hope springs eternal. I want the system to at least go ahead and register the ones that connected, before it aborted,but that's asking too much I guess. It’s a clunky arrangement.
Old Jul 20, 2022 | 08:18 AM
1 bad apple........ That's how it works.
LT1GMC
May 11, 2015 10:06 AM
speedster
Jun 19, 2010 04:58 PM
redradt25
Tires & Wheels
11
Apr 23, 2010 07:37 AM
hhr/49suburban
Sep 14, 2007 12:40 AM
Lee3333
Dec 27, 2006 01:00 PM
