Synthetic over Conventional Oil????
Old Jul 27, 2009 | 06:08 PM
3amigos's Avatar
Question Synthetic over Conventional Oil????
As a long time driver, I have always had the "every 3 months or 3000 miles" systematically pounded into me.
Then I buy a 2007 HHR with a DIC that has an Oil Life Monitor. It tells me that the above statement is hogwash, that changing oil that often is a waste of precious resources, and that I should change my oil when they say so. So I bite.
Problem is, I am still a little leary. So my last oil change I switch to Valvolive Synthetic 5W-30. Figure the longer change intervals synthetic would be better. Manufacturers recommendation. Now, it taps a little on start up, sometimes I can here a very slight tap at idle. Oil level is fine. Car has 11,000 miles on the clock. Flushed the oil before switching to synthetic from conventional oil.
Does anyone have any ideas?
Old Jul 27, 2009 | 06:11 PM
oneton's Avatar
IMHO; Normal
Old Jul 27, 2009 | 08:06 PM
vinmans brew's Avatar
The 3 month/3000 mile thing was created to sell oil. It will not hurt to do it more but you do not need to.
Old Jul 27, 2009 | 08:15 PM
catdaddy137's Avatar
normal ?
does that mean it is abnormal for mine not to tap ? .....my 08 2.4 used to tap for a second ...i now got over 85,000 miles....i can't remember the last time i heard it....it has been a while..probably back when the weather was cold....i been using mobil 1 syn...i started using 0w 20w , and i think it was 5w 20w that i used last time....i have heard alot of people say that most ecotecs do tap for a second before or after cranking...i guess when mine broke in it made the oil pressure hold better somehow.....could it be because the jet brand module i installing changed the timing ?....i really haven't thought about it , 1 reason is because it hasn't done it , 2nd reason was i just seen this post.....oh , i have never heard mine tap while at idle , only at startup.
Old Jul 27, 2009 | 08:55 PM
timberwarp's Avatar
Similar question with Synthetic vs Conventional, how far does anyone go on their oil life meter before they change? 40%? 30? Lower? I got my HHR used and I will definitely want to go to Synthetic, especially from reading about a slight performance increase.
Old Jul 27, 2009 | 09:00 PM
hhrcrafty's Avatar
I change it when DIC displays "Change Oil Soon". That means within one or two fuel fills or <5% oil life left.
82,500 miles. No tapping or knocking. All conventional or blend fills, house oil.
Old Jul 27, 2009 | 09:03 PM
urbexHHR's Avatar
Yeah, I just put synthetic in on Friday...not sure how long I'm going to wait on it. I typically don't drive a lot, so I think I'm going to do it time wise over miles....
Old Jul 27, 2009 | 09:12 PM
REX347's Avatar
Whats the average miles people are seeing when the change oil soon notification comes on?
Rex
Old Jul 27, 2009 | 09:14 PM
TomsHHR's Avatar
I got 13,000 miles off my last Valvoline synthetic 5w30 the last change, I do change filters only every 4,000 miles. That may be why I get more miles out of it. But somebody will tell me different..
Old Jul 27, 2009 | 09:45 PM
urbexHHR's Avatar
