TCM trouble code help
Old May 9, 2017 | 08:39 AM
Here
https://www.chevyhhr.net/forums/how-...cations-56504/
Old Feb 11, 2019 | 01:08 PM
Dawn Curtis's Avatar
Originally Posted by donbrew
The speedo isn't working because the TCM isn't working.
Both of those codes are TCM communication faults. I would be looking at wires and fuses.
The connector on the bottom of the trans passenger side is the vehicle speed sensor. It is vulnerable to varmints and running over things.
Fuse #43 under hood.
You might try disconnect/reconnect the TCM connector. (disconnect negative cable on battery first).
Is the "Darth Vader" plastic hood still covering the ECM & TCM? Any chance that somebody touched the TCM with a hot wire?
what to do if it was touched with hot jumper cables??
Old Feb 11, 2019 | 03:00 PM
Get a new one and have it programmed.
Old Feb 11, 2019 | 05:09 PM
Welcome to the site, X2 it’s most likely toast from the voltage spike!
09hhrblack
May 15, 2014 05:45 AM
douglas
Mar 5, 2014 10:28 PM
GDZHHR
Oct 26, 2009 04:49 PM
Popi
May 18, 2009 01:34 PM
Bowtie388SBC
2.4L Performance Tech
May 24, 2006 06:32 PM
