Tell us about your Front End Noise
Old Jan 26, 2012 | 06:12 AM
FLORIDA's Avatar
This should not be such a mystery. I am still trying to fix it. Replaced 2 struts, 2 top rotating bearing plates, 2 sway bar links, 2 lower control arm bushings, just one axle. All that is left is one more axle ane 2 sway bar bushings. any thoughts? Front end is almost all new.
Old Jan 26, 2012 | 07:22 AM
Originally Posted by HHR~SS~Panel
Going to here soon..... ~
Since it was recently fixed.. with a different throttle body
At the Time it was in that was the more important problem
To get it running right again
Its also seems to need brake pads up front, So maybe they can
look at the front end for the noise at the same time ~
HHR~SS~Panel,
Let me know how everything goes!
Thanks,
Evan, Chevrolet Customer Service
Old Jan 26, 2012 | 06:44 PM
SWAY BAR BUSHINGS!! I didn't realize you had not already done them. If you put the front up on stands and have your beautiful assistant turn the steering wheel lock-to-lock while you watch the sway bar you will see/hear/feel the clunk as the bar traverses. It is supposed to, but it will bang into the frame when the bushings wear.
Old Jan 30, 2012 | 09:35 AM
FLORIDA's Avatar
Found my problem - It was sway bar related but not the bushings. The sway bar links bolt into a larger hole in the bar. It has to be torqued down tight or it will slide back and forth within the hole and cause a knocking/ clunk sound. It is hard to tighten because it requires an allen wrench and a 18 MM wrench. Knocking/ clunk sound is GONE!!!!!!!
Old Jan 30, 2012 | 05:23 PM
hyperv6's Avatar
I had a clunk in my 95 T bird with only 5,000 miles. The rear sway bar link came lose. I had to snug it down.
Stuff like this happens often no matter the brand.
My buddy had a Sonata that a weld broke on the bar and it hit the ground came up and did a lot of damage.
Old Feb 5, 2012 | 04:38 PM
  #26
alexrckid's Avatar
larger hole in the bar..?? does your sway bar have two holes at the ends where they connect to the links..??
Old Feb 5, 2012 | 04:53 PM
  #27
I don't get the "Allen wrench" part either, the only Allen wrench I can think of on MY HHR is the headlight adjusters. But, yes the Squash nuts are difficult to get tightened down, you do need to hold the "flats" while tightening the nuts, I did have that problem at one time! May be that some replacement parts have an Allen arrangement rather than a "hex flat", just not either of the ones I've used.
Old Feb 6, 2012 | 10:55 PM
  #28
voigtsga's Avatar
I have an '07 LS that I bought 1 1/2 yrs ago with 60k and now 90k on it. I've replaced the sway bar end links with Moogs, sway bar bushings with aftermarket greasable ones, both strut assemblies to include top bushings, intermediate steering shaft, and I still get a very noticeable clunk when I go over any kind of ripples in the road or especially a speedbump. I've never had a car before that clunks like this, and I've owned a BMW, VW, Chevette, Oldsmobile, Nissan, Honda, and now this HHR. There has to be some kind of design flaw that enables something in the suspension to hit something else under the car. Search me what though. No one seems to have a real reason as to the cause of this. I really like this car overall, and have just decided that its a characteristic that isn't going to change and just comes with the car. Its kind of annoying, but it isn't a show stopper.
Old Feb 7, 2012 | 04:37 PM
  #29
Did you by any chance use the Monroe Quick Struts? That may be part of your current problem. Some say that the springs are wrong for the HHR, look for a wear pattern between the top coils, they may be banging into each other. I have not had the problem, just read about it here.
Old Feb 7, 2012 | 09:06 PM
  #30
voigtsga's Avatar
The strut assemblies that got put on my car are the Monroe ones. I'll have to take a look and see if there is any wear at the top of the springs, although I don't think that is what is happening. I have some ripples in the pavement close to my house, and just going over them at 10mph produces a clunking sound in the front end.
arkansashhr
34
Mar 1, 2015 03:11 PM
bal07hhr
Jun 20, 2014 04:33 PM
badandy519
Aug 28, 2013 01:18 AM
fsc44
Aug 29, 2012 02:11 PM
HHR321
Feb 17, 2007 11:18 AM
