Temperature Gauge, and over heating issues
Old May 29, 2019 | 07:50 PM
Well, as it heats up, it pushes the liquid into the recovery tank, so that could be the bubbling.
It does seem to be running a bit hot, perhaps a clogged radiator or heater core. Maybe a bad water pump. Was it behaving the same before the new water pump?
Maybe just needs a good burping.
Edit: on another read, a burping is very likely the fix.
Old May 30, 2019 | 10:17 AM
And if the cap is weak, then the boiling point would change, if it’s not holding at 15 lbs
Old Jun 2, 2019 | 08:06 PM
dmczeal's Avatar
Thanks to you all, it turns out that it was the radiator cap, problems solved. I was not trying to save $10, I was trying not to waste it. I did replace the thermostat along with the cap and put dex-cool in it. Now it does goes to 217° and the fan turns on with no bubbling. Driving around town and on the freeway it stays at 189° to 199°. Thanks again for all your help, it is greatly appreciated.
Old Jun 3, 2019 | 08:23 AM
Awesome, fixed!! Enjoy the drive!
Old Jun 5, 2019 | 06:35 PM
guppy's Avatar
Originally Posted by Oldblue
The overflow tank bubbles ? I missed that, check the pressure cap. After you burp the system.
Good catch OldBlue!!
Old Jun 5, 2019 | 06:57 PM
I’m not just a pretty face, I’ve just applied common sense , some old school things still apply.
Bodean64
Apr 8, 2019 08:54 PM
tom.tbd@aol.com
Oct 15, 2017 11:34 PM
GibsonHHR
Jun 11, 2015 06:41 PM
Charlottesalami@yahoo.com
Maintenance and Upkeep
May 23, 2014 10:24 AM
Mark Twain
May 13, 2011 10:08 PM
