Time chain guide bolt plug
Old Jun 6, 2018 | 09:05 PM
Gr1ff1n's Avatar
2006 HHR 2.2 Time chain guide bolt access plug on the engine stripped, (10 mm hex bolt), i have a broken left timing chain guide i need to replace but i am out of idea's to get that access plug off. Have tried to j/b weld the hex bolt to the plug, no luck, channel locks but really tight area no leverage, any help would be grateful,
Old Jun 6, 2018 | 09:33 PM
I would try a Torx, that might get a grip.
You can take the motor mount off and jack the engine up or down maybe get some room to work.
Old Jun 6, 2018 | 09:49 PM
Gr1ff1n's Avatar
Thannks will give the Torx bit a try, hope there is enough surface In the bolt to latch on to,, maybe I'll even try a 11mm
Old Jun 7, 2018 | 08:11 AM
Try a chisel and hammer to get it moving, then Replace the cover and upper bolt with one of these
Broken Ecotec front timing chain guide bolt? Have I got a fix for that! - General Forum - ecotecpower.com - the ecotec enthusiast site
Old Nov 29, 2019 | 10:26 AM
Mark Stephens's Avatar
Replacement part
Is this user still active? And are these replacement bolts still available? I tried to send an email to the one in the post but it got kicked back
Last edited by Mark Stephens; Nov 29, 2019 at 10:26 AM. Reason: Adding to the message
Old Nov 29, 2019 | 12:02 PM
Why would you post the same thing in two different forums, especially since he is not a member here?
ie: Broken Ecotec front timing chain guide bolt? Have I got a fix for that! - General Forum - ecotecpower.com - the ecotec enthusiast site
Old Nov 29, 2019 | 12:32 PM
Cat Man HHR's Avatar
I thought Dorman made a bolt.
Old Nov 29, 2019 | 02:17 PM
the_shmoo's Avatar
Yes Dorman does supply that bolt.
https://www.autozone.com/internal-en...rchText=917954
Hope this helps.
Old Nov 29, 2019 | 04:00 PM
Yes, Dorman now has the plug it’s available on line or at your local parts palace, ZZP sells it also.
the kit I mentioned above included ARP bolts for the tensioner arm and the lower of the front guide, nice package.
Cat Man HHR
Maintenance and Upkeep
28
Feb 25, 2022 01:10 PM
UWZerokoolX
"How To" Tutorial Library
19
Sep 24, 2020 07:47 AM
Samp42
7
Jul 12, 2019 02:22 PM
fastsuv
Jan 24, 2017 10:37 AM
rezonatefreak
Apr 1, 2016 07:53 PM
