timing chain guide broke
Old 11-02-2014, 01:39 PM
vulcan scott's Avatar
new to the forum my sons 09 hhr has 2.2 plastic guide broke . how likely of bent valves ? it happened on start up and has been turned over with the starter but not run. thank You in advance for Your replies !
vulcan scott is offline
Old 11-02-2014, 01:49 PM
It would really depend on when the guide failed, high rpm or low rpm, and whether the timing chain went slack enough to jump a sprocket tooth on one or both of the cams.
Unfortunately, this is one of those "you aren't going to know until you get in there" deals. Unless you can lay your hands on a borescope to look at the piston crowns for "witness" marks left by the valves.
If the stars aligned right, and luck is on your side, the engine didn't jump time. But you'll find out for sure when you replace the chain and guides.
843de is offline
Old 11-02-2014, 06:14 PM
X2 time for a timing chain set, head gasket and while its apart a new water pump! Some kits include one, fingers crossed the Pistons did not bend any valves.
Oldblue is offline
Old 11-09-2014, 06:40 PM
Timing Chains
Just finished Sons car . No bent valves . Balance shaft chain was 1 tooth off I guess ever since new .Replaced guides chains gears & tensioner runs smooth as a baby tush .oh and only 4.5 hours to complete !
Old 11-09-2014, 07:23 PM
Do you have a DTC P0315? That will require a scantool to relearn the crankshaft position sensor.
If the engine was ever turned counter-clockwise the chains will jump teeth.
Oddly enough the "book" says 4 hours labor!
donbrew is offline
Old 11-09-2014, 07:43 PM
Nice job - glad you got it resolved.
whopper is offline
Old 11-09-2014, 11:42 PM
Cool beans, glad you got it fixed up.
843de is offline
Old 11-10-2014, 06:05 AM
Nice work!!!
Oldblue is offline
Old 11-10-2014, 06:30 AM
baritone275's Avatar
should I replace timing chain tensioner before it fails?
2010 LS, 60K, just bought it last month. It is a GM CPO car with a 12m/12k warranty, but this car is for my daughter and I don't want any disasters while she's driving.
What are everyone's thoughts on having the timing chain tensioner replaced proactively, i.e. before it has a chance to fail? I have no problem with the cost if everyone thinks this is a good idea.
Thanks.
baritone275 is offline
Old 11-10-2014, 06:41 AM
For your piece of mind change it, especially if you hear the noise on start up! It's an easy swap out.
Oldblue is offline
Quick Reply: timing chain guide broke
