Timing chain whine after water pump replacement
Hi there everyone I am having a well known whine issue with my hhr since having the water pump replaced I’m guessing the balance shaft tensioner may need to be reset but I heard that even then it may still whine so would it be best to just replace the whole chain and get a new kit to do it the car does have 160,000 miles on it so it might be time.
Welcome, to the site, change both chains.
https://www.chevyhhr.net/forums/how-...in-kits-60394/
pay at attention to that front guide.
Follow up
So a week later car still whines and check engine light came on took it too the mechanic and pulled the codes it was a vvt selonoid so it was replaced and the car still whines so I’m guessing that’s not good I heard that going through vvt selnoids is due to a timing issue no mechanic has figured out why it makes noise though so any thoughts
The code was due to the vvt selonoid i just had the water pump replaced and since then it just been making the whine noise i also had to have the manifold replaced as well. the only thing he replaced this time was the seloniod.
Lucidinferno
Mar 8, 2019 12:44 PM
LG7rumble
Apr 30, 2018 10:02 AM
