Timing set
Old Apr 4, 2021 | 01:49 AM
Isolated's Avatar
Timing set
My timing gears indicate that the engine has jumped time or the chain has stretched. Is there a way to tell if valve damage has occurred? 2008 HHR 2.2 Motor cranks but no start. I will not crank again until I know about the valves.
Old Apr 4, 2021 | 05:33 AM
Reset the chain to time and then, perform a compression test.
Old Apr 5, 2021 | 11:04 AM
Or, get a bore scope camera and look through the spark plug hole. They are under $20 and attach to a smart phone.
You are probably OK unless the chain broke.
Old Apr 13, 2021 | 10:47 AM
PulpFriction's Avatar
I don’t know what you mean by, “My timing gears indicate...” Could you expand on that to clarify?
Old Apr 13, 2021 | 03:59 PM
The timing marks don’t line up! The crankshaft at 5 o’clock, the intake cam at 2 o’clock and the exhaust cam at 10 o’clock
Old Apr 19, 2021 | 04:10 PM
OP said, “My timing gears indicate that the engine has jumped time or the chain has stretched.” Further explanation is still needed.
Isolated, could you explain what’s happening that makes you conclude that?
Old Apr 19, 2021 | 06:29 PM
That how you can tell the timing marks in the sprockets and chain aren’t in the correct position, depending on how much they are out, the valves could be bent from hitting the pistons.
68Chrgr
Maintenance and Upkeep
25
Oct 4, 2025 07:33 AM
2008OutTheGate
2.2L Performance Tech
May 2, 2019 08:47 PM
vulcan scott
Nov 11, 2014 06:17 PM
han92
Oct 25, 2014 01:23 PM
skuzzlebutt
Nov 11, 2013 09:16 PM
