Tranny??? or something
Old Sep 25, 2012 | 06:20 PM
Alexwsilver2010's Avatar
my little ride has been making an unusual noise... It starts at about 30mph and stays consistent when gaining speed... It is not engine noise, I know that... It kind of sounds like when I had AT's on the truck...
I took the wheels off, no play in the hubs, the CV axles look ok, and dont seem to have any play.. All of the linkage and tie rod look good as well.. I know I am in need of new struts, but this isnt a strut noise...
ANY suggestions?? Trans, power steering?..
70k on the OD
Old Sep 25, 2012 | 07:20 PM
swerv0428's Avatar
What year is it and what engine? I would guess wheel bearing or the tranny
This may sound stupid but how are the air pressures in your tires. A low tire can cause a similar noise.
Old Sep 26, 2012 | 06:49 PM
2010, 2.2, Auto,
I have check the tires, pulled the wheels and checked the bearings
Old Sep 26, 2012 | 10:54 PM
swerv0428's Avatar
Then id check with a dealer. Hopefully its covered under the powertrain warranty.
Old Sep 27, 2012 | 12:18 AM
prod's Avatar
the amount of runout on bad bearings is very small, you may not notice it by feel. Gm uses a micrometer to measure but I forget what the limit is.
Gmando
22
Jan 16, 2022 05:56 PM
hhrted
Jun 9, 2013 10:48 AM
dpoll995
Sep 21, 2008 05:28 AM
agentsmith23
Jul 20, 2008 01:27 AM
Lee3333
Jan 31, 2008 09:16 PM
