Transmission
Old Aug 14, 2019 | 09:54 PM
Jessica Rogers's Avatar
Originally Posted by donbrew
If he only put 1 gallon in it is nearly 1 gallon short of full; it should have taken 7 qts.
I would check the level first. It would be nice to know what was put in, I can't believe somebody just walked into the store and didn't notice there were several different types of fluid. Either type of DEXRON is OK. If he put something else in you are going to need a complete flush and fill.
The good news is the solenoids are replaceable for less than a new trans.
I'm sorry I'm still trying to figure out how to use the site! What does a complete flush Intel?
Old Aug 14, 2019 | 10:06 PM
A complete load of ATF is 12 qts, what you replace at home is only 7 qts, if you have it flushed ALL of the fluid gets replaced. Any decent shop can do it, just tell them somebody put an unknown type of ATF in it.
Old Aug 14, 2019 | 10:14 PM
Can't afford to take it to a shop , my brother is doing it what does he need to do?
Old Aug 15, 2019 | 12:06 AM
Originally Posted by Jessica Rogers
He cant find the container I guess he threw it away, but I went to auto zone today and put it on code reader, it pulled codes: p0741 torque converter solenoid circuit performance or stuck off. And p0757 shift solenoid b stuck on . So my question is do I try changing fluid and filter first to see if that fixes it and these aren't a false read or?
Wait. What ? How did you drive it to Auto Zone ? Thought this whole thread started with a fluid change and the car won't go in drive.
Besides that. If it would go gear, why would you drive it ? Was already discussed that with the wrong fluid you could damage or burn up the transmission.
And "He can't find the container". Well, why not just go to that store with him and tell him to point out the kind that he used.
Old Aug 15, 2019 | 07:16 AM
I'm a single mother of four who just lost her job cuz my car is broke down I'm feeling desperate and frieking out I didnt know what to do I was trying to get it fixed.
Old Aug 15, 2019 | 07:39 PM
  #26
guppy's Avatar
I would recommend NOT driving it, as I stated earlier if you are low on fluid this will most DEFINATELY kill your transmission. At the very least, drain the transmission and refill with cheap Dextron III. It takes about 7 quarts. Once you have checked for proper level, take it for a quick test drive and report back.
Old Aug 15, 2019 | 11:40 PM
  #27
https://www.youtube.com/watch?v=3-rJaOg8aLo
So drained it changed filter and fluid , put in ac delco brand dexron. No change
Old Aug 16, 2019 | 08:10 AM
  #28
Sorry, if you can't take it to a professional there isn't much we can do on the interwebs. It most likely needs new solenoids, they are inside the transmission.
a_bartle
Maintenance and Upkeep
Jul 20, 2017 01:21 PM
Danny Thomas Sr.
Drivetrain (Excluding Engine)
May 27, 2016 01:07 PM
Herbie
66
Jul 7, 2014 10:52 AM
wgiff
Jan 26, 2011 02:44 PM
55f250
Aug 21, 2010 11:10 AM
