Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
Just got car back from transmission shop. Transmission is just fine this is an electrical communication issue that is probably going to be a nightmare to figure out.
check resistance valves thru the harness in the transmission and solenoids….might save you a lot of trouble…..
