Transmission Control Module
Old Nov 23, 2013 | 05:09 AM
cpcook's Avatar
Has anyone have to have this replaced? Someone told me to replace it at 140,000 miles because they have a history of going bad at that mileage and if that happens than a $500 module replacement possibly becomes a $2000 transmission fix.
He said if you replace it I will get 200,000 miles out the transmission.
I have a 137000 miles on my 2007 lt1 and wondering if this would be a good PM move on my part.
TIA.
Old Nov 23, 2013 | 09:04 AM
Never heard that before from anyone.
The TCM does just that, it Controls the transmission while interacting with the other interrelated powertrain modules. A failing TCM can give you hard shifts, as can a half dozen other faults that come to mind.
So I suppose that driving about for tens of thousands of miles with a bad module could lead to failure of the transmission, it's nothing that needs to be changed out on a time/mileage related basis.
It sounds like someone trying to sell you an expensive part($500 ?!?) + a line of B.S.
The best way to keep your 4T-45E transmission happy is to follow the maintenance schedule in your owner's manual. Or as a lot of us geezers do, service the transmission every 30,000-50,000 miles.
Old Nov 23, 2013 | 09:13 AM
X2 clean trans fluid and filter every 50,000 is well worth the time and effort, take it from us with the personal experience with these trucklets
Old Nov 23, 2013 | 09:19 AM
db/sb's Avatar
$500 for an HHR TCM?? I've seen AC Delco factory replacement units for as low as $60 on Amazon and never more than about $135 anywhere else. And that's for a new (not rebuilt) unit. Even allowing for programming/labor it would be well under $500.
Old Nov 23, 2013 | 03:04 PM
A brand new scam.
Old Nov 24, 2013 | 03:16 AM
cpcook's Avatar
thanks guys
Old Nov 24, 2013 | 11:15 AM
didn't Roger Ramjet battle the Solenoid Robots with Lance Crossfire back in the '60 s. they were here to take over the world, now just your wallet!!!
Old Nov 24, 2013 | 11:30 AM
db/sb's Avatar
I remember Roger Ramjet (and his Eagles-Yank, Doodle, Dan and Dee). They lived about three hours away in Lompoc, California.
leeniep
May 21, 2014 08:48 PM
dsm2007hhr
Dec 5, 2007 10:37 PM
