Trany flush
Old Mar 1, 2019 | 12:40 PM
Changing axles is a very minor thing a screwdriver not a claw. I could do one side in less than an hour in my driveway. The seal can be had for a lot less than $60:https://www.ebay.com/itm/For-2006-2009-Chevrolet-HHR-Auto-Trans-Output-Shaft-Seal-Timken-81363HV-2007/292800823027?fits=Model%3AHHR&epid=4025455630&hash =item442c49fef3:g:5TUAAOSwNp1b3Prn:rk:2:pf:1&frcec tupt=true
And https://www.ebay.com/itm/Oil-Seals-Output-Shaft-Seal-Kit-Ref-5693-16148/221685707484?fits=Model%3AHHR&hash=item339d7f72dc: g:Q7gAAOxy7q1RY0Kt:rk:10:pf:0
The GM MSRP for part #24233355 is $23.53 each. I don't know where $60 is coming from.
As I said earlier the plug you pull to check the fluid level is on the passenger side, so a drip there is expected.
Old Mar 1, 2019 | 12:49 PM
When , I changed mine, I disconnected the ball joint and swung the strut out enough to get the inner piece of the axle to pop out, then changed the seal, then put the axle back into place , replaced the ball joint into the knuckle and followed correct torque procedures in the pinch bolt.
3 years later and still dry both sides.
MWG2
Maintenance and Upkeep
15
Oct 26, 2017 09:22 AM
Herbie
66
Jul 7, 2014 10:52 AM
C-DUB
Oct 2, 2013 07:00 PM
ChevyGuySS
Sep 27, 2012 08:15 PM
Beachbum1
Apr 9, 2012 09:23 AM
