Trouble codes
Old Aug 16, 2022 | 08:51 PM
Aj1968's Avatar
Trouble codes
My car started missing again today and the engine light was flashing. I went to Autozone and they pulled code 0300 as primary and P0128 and P0352 as secondaries. I do have a new thermostat coming as that code had been showing intermittently for a while. What am I looking at as possible culprits for the other codes? Any help would be greatly appreciated. Thank Y'all for your help.
AJ
Old Aug 16, 2022 | 08:54 PM
Aj1968's Avatar
Trouble codes
I forgot. The car is a 2007 with the 2.2l , auto, and 273,000 miles.
Old Aug 16, 2022 | 09:12 PM
P0352 is the cause of the P0300. It means that the control circuit for coil #2 has a problem.
Start by switching coil #2 and any other see if the P0352 moves. The 2 means cylinder #2, if it was P0353 it would be #3 etc. Cylinder #1 is closest to the passenger side. If it does move you need a new one if not it is a wire problem.
The P0128 is either you did not use a AC,Delco 131-158 t-stat or the tempsending unit has a problem, either a wire or a bad sensor.
Old Aug 18, 2022 | 12:21 PM
Aj1968's Avatar
Problem solved
Thank you to everyone. I had this problem before but that time the wire had pulled off the coil but I had bought a new coil and had it sitting on the shelf. This time the plug seemed like it was on tight so I just swapped out coils and it is back to full song. As for the thermostat I haven't changed it yet but have the proper one coming for that. Does anyone have any pointers on how to replace it that are relatively painless? Thanks again everyone. I still love my HHR even though there are still lots of haters out there.
AJ
Old Aug 18, 2022 | 12:44 PM
Here's my tip: tape your universal joint so it doesn't just flop all over except where you want it to go! I didn't remove any hoses, but I did back the big clamp out of the way.
Old Aug 18, 2022 | 02:09 PM
Any way you do it you will end up with at least one scratched up knuckle, pain ensues.
It is just 2 bolts, but they are well guarded.
willyj8749
May 13, 2022 09:44 AM
iluvmud
Sep 9, 2016 08:16 PM
Lions
Mar 2, 2015 06:50 PM
walkowg
2.2L Performance Tech
25
Dec 5, 2014 07:36 AM
Songman
Oct 27, 2009 03:48 PM
