Valve cover installation help 06 2.4
Old Jul 18, 2018 | 01:31 PM
  #41
Originally Posted by Oldblue
The oil has to get down the valve stem past the guides to lubricate the guides but as the wear to much oil can be sucked in during the intake stroke.
I'm tending to agree with you that leaky valve guides can't be diagnosed with a leak down test. I'd like to hear sleeper's theory, though.
Old Jul 18, 2018 | 02:12 PM
  #42
Cat Man HHR's Avatar
Originally Posted by sleeper
True, but loose clearance on valve guides will definitely be detected on a leak down test.
It can tell one if it's the guides, or the rings. You just have to listen during the testing.
How, when both are closed for a leak down test?
I guess it's time to show how a leak down test is done.
Here is one youtube about it:
Old Jul 18, 2018 | 04:32 PM
  #43
BLKHHRSS's Avatar
I think that you can do a leakdown test by pulling the air on the other side of the valves, using a plug and a vacuum. Not really a leakdown test though, and only done when the head is off the motor and sitting on the bench. Or at least that is the way I remember it being done, and then I'm still not sure if that shows up the worn guide. Just throwing that out there. But I'm going with the rest of you on this.
Old Jul 20, 2018 | 09:14 PM
  #44
OK, I mis-spoke I meant valve seats.
87silver
Feb 7, 2010 12:45 PM
VIRGINIA_HHR
Maintenance and Upkeep
28
Sep 20, 2009 06:11 PM
Lee3333
Sep 13, 2006 09:02 PM
GhstRider
2.2L Performance Tech
13
Sep 11, 2006 09:49 AM
