View Poll Results: Cam snout pressed on camshaft, can it move?
Camshaft snout pressed on
0
0%
Can camshaft sprocket end rotate without moving lobes due to being pressed on
0
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
Valve time or cam
Old Jan 5, 2022 | 05:07 PM
dben719469@aol.com's Avatar
Valve time or cam
The way I understand this is the cam notch’s on cam without the vvt sprockets on it should be at 5 intake and 7 exhaust tdc . My exhaust is at 12. The intake is in right spot at 5.The valves are closed lobes pointing up. Question is can cam snout move, is it a press fit that can move.
Old Jan 5, 2022 | 06:28 PM
First off prior to the poll,
What year?
which engine?
and really no poll needed, the camshafts are solid steel.
https://www.chevyhhr.net/forums/main...oke-tdc-58437/
Page 9 image 17
http://www.ddmworks.com/assets/image...uild%20Kit.pdf
For a 2.4
Old Jan 5, 2022 | 06:57 PM
Here we see the timing chain end of the exhaust cam for an Ecotec 2.4
Old Jan 5, 2022 | 08:46 PM
ALL 3 marks need to line up to worry about timing! If you are replacing the timing chain just line up the marks, don't think too much.
FIG. 136 is for something else. The keys that line the sprockets to the shaft.
The marks on the sprockets should be at 11 and 1 with the crank mark at 5:30 (all times approximate).
dmczeal
2.4L Performance Tech
13
Aug 8, 2020 10:03 AM
Trevor Alcorn
Jul 20, 2017 09:17 AM
Dasstrum
Maintenance and Upkeep
16
Feb 19, 2017 01:45 PM
cobra94svt
Jul 12, 2015 08:02 PM
savm99
Apr 18, 2012 04:17 PM
