Water dripping inside from AC
Old Oct 15, 2012 | 11:08 AM
dwt1020's Avatar
Sorry if this has been asked and answered.
My Wife's 2006 HHR has a water drip on the passenger side when the AC is on. I have looked but can't find issue clogged drain tube. Can some one help with this? I am not much of a car guy so I'll need "special help", if you know what I mean... Pictures would be great...
Thanks in Advance
david
Old Oct 15, 2012 | 05:04 PM
wmsburghhr's Avatar
Thanks in Advance
david
here is pic of drain tube,https://www.chevyhhr.net/forums/show...16&postcount=2
If the floor gets wet when it rains, then it is the butyl patch under the cowl. Use search button at top of of page ( close to the log out button) to look for tons of info on that problem (design change with the 08 models)
Old Oct 15, 2012 | 05:08 PM
dwt1020's Avatar
Thanks so much.. I appreciate it....
For now the Butyl Patch seems to be holding. We had a big rain just the other night and all was dry.
Thanks Again
david
Old Oct 16, 2012 | 01:13 AM
The A/C drain is on the pass side, down low on the firewall (in engine bay).. Easier to see from under it..
Old Oct 16, 2012 | 11:52 AM
JazzDad's Avatar
I had lots of problems with the a/c condensate drain clogging up and dumping LOTS of water onto the passenger side floor. (Fortunately I have Husky floor liners, which prevented the carpet from getting soaked.) I had rodents getting into the blower box, bringing nest material. I finally made a screen out of 1/4" hardware cloth (we call it rabbit wire) under the cowl.
They have eaten all the insulation off the firewall, too.
I went to replace the engine air filter last night and found mouse meal remnants in the air filter box. I dumped all the acorn shells out, washed the urine and feces out, and fabricated a screen to fit into the inlet end (inside the fender well) of the fresh air intake tube.
I would say, 'Now let's see 'em get in', but I know better than to challenge the mice gods.
raminator01
Oct 1, 2022 07:57 AM
pindars
Drivetrain (Excluding Engine)
Aug 5, 2014 06:28 AM
Bahbushkah
Jun 5, 2014 04:58 AM
gerrbear
Oct 5, 2012 12:11 AM
Goose
Jun 24, 2008 10:46 PM
