what is this june bug/cicada noise coming from my engine?
Old Aug 25, 2022 | 05:46 AM
Does the sound change with the AC turned on?
Old Aug 25, 2022 | 07:51 AM
Air cleaner bracket, RC cola cap stuck in the alternator (really), loose wheel house liner, loose bumper cover
Old Aug 26, 2022 | 08:19 AM
PulpFriction's Avatar
Originally Posted by RetroHHR2020
if it is the wheel hubs/bearings, wouldn't the sound be there all the time while driving? would the frequency change at different speeds?
Not necessarily. Same for CV joints.
in my original post I explain that it only starts making the sound once you hit 2500rpm or higher while accelerating, but once you are at speed regardless of rpm, the sound is no longer there.
With bearings as well as CV joints, the noise is caused by damaged surfaces rubbing/grinding against each other and causing vibration. Under acceleration, the forces are greater so that effect would likely be more intense. And noise will be more audible at certain speeds due to resonance.
My money is on a CV joint but I wouldn’t eliminate a bearing.
Old Aug 26, 2022 | 09:15 AM
greg8453's Avatar
Bad bearings in the early stage usually only make noise when under a load.
Old Aug 26, 2022 | 11:21 AM
Bad hubs can scrape and grind at low speed while turning, howl at highway speeds and wobble at city speeds.
In theory hub bearings are always under load, the weight of the car engine and transmission bare down on the front hubs.
Old Aug 26, 2022 | 03:58 PM
jimvw's Avatar
Not when the wheels are of the ground...
Old Aug 26, 2022 | 07:55 PM
greg8453's Avatar
https://www.youtube.com/watch?v=y6WmC6dber8
Well I can't beat that.
Old Aug 26, 2022 | 07:58 PM
greg8453's Avatar
My point exactly. I don't think I worded it well at all.
Old Aug 27, 2022 | 07:36 AM
I just changed both hubs out last week, after 2 1/2 years and 40,000 miles. With our pot hole ridden roads , they failed. I always change both sides!
Old Aug 27, 2022 | 06:12 PM
RetroHHR2020's Avatar
will update more later as i do repairs/tune up... to answer oldblue's question, does the noise whether ac is on or off... also only seems to do it on initial acceleration - which i assume is either in 1st or 2nd gear, but if you are already going 40+ and it's in 3rd or 4th, it doesn't seem to make any sound at the 2500 rpm mark... the more I listen for it the more it seems it is a very brief sound.
aradmahogany
Maintenance and Upkeep
24
Aug 7, 2020 06:27 PM
HHRriver123
Mar 6, 2019 12:17 PM
skyline26
Oct 29, 2014 04:26 PM
F-16C
Feb 23, 2013 12:31 PM
esmarkey
Sep 2, 2008 03:27 PM
