What is wrong with my hids!!!!!!!!!!
Old Jan 28, 2011 | 12:53 PM
ufvj217's Avatar
ok im getting a little angry now lol. this is my 2nd set of DDM 55w hid's. i KNOW im installing them correctly. i just put the 2nd set in, and the passenger light worked, until i started the car. same thing happened with the first kit.
WHAT can i be doing wrong??????? its the hi/low beam kit by the way.
Old Jan 28, 2011 | 12:56 PM
Send a PM to Gas Man. He has the same set.
Old Jan 28, 2011 | 01:02 PM
ufvj217's Avatar
He's helped me alot. im waiting for him to see this thread lol.
Gas man, PM me ur number. ill give u a call later on. i just dont get what it is. nothing is hooked up wrong
Old Jan 28, 2011 | 02:30 PM
nacademus's Avatar
Turn your lamps off while your car is running, count to 10, then turn them on. The 55W kits are known to do this. Some ballasts are intolerant of the drops in voltage when you go to start your car (which will cut the headlights briefly) and they shut off.
Old Jan 28, 2011 | 02:35 PM
Now that you said that I remember Jason (saxrocks2009) said he had a problem with his passenger side not coming on like that. I don't think his are DDM Tuning but he said he turns them off and then back on and all is fine.
Old Jan 28, 2011 | 05:44 PM
ufvj217's Avatar
I've tried that. No go
ufvj217's Avatar
ddm said try and plug a halogen bulb into the stock connector on the passenger side and see if it works
Old Jan 28, 2011 | 05:55 PM
lunchbox's Avatar
i have to toggle my lights off and on a few times until the passenger side stays on. i think it also has to do with temperature too, mine act up when it gets cold.
Old Jan 28, 2011 | 05:59 PM
It sounds like the ballast is intolerant of the voltage drop as nacademus stated. Maybe you should turn the ignition on and select "auto lights off" to see if they go on correctly after the engine is started.
Old Jan 28, 2011 | 06:02 PM
Not sure if it has anything to do with it but I know Gas Man said he had pulled the fuse for the DRL.
