What is wrong with my hids!!!!!!!!!!
Old Feb 2, 2011 | 07:09 PM
Gas Man's Avatar
ufvj... PM coming your way... we can discuss this on the phone and get thru it a lot faster.
Old Feb 2, 2011 | 08:39 PM
saxrocks2009's Avatar
mine only wouldnt work when i used the key fob to unlock the car at night. it comes on right everytime I start it
Old Feb 4, 2011 | 12:24 AM
Low-n-Loud's Avatar
My driver head light rarely comes on when I start my car. I have pulled the DRL fuse and relay but as you know, it didn't help. I havent talked to anyone on here about it but like mentioned in a previous post, it definitely has something to do with the low voltage at start up. Im pretty sure all you need is a relay to send a higher amperage 12v to the bulb at start up. If that's the case I believe the the diagram would be: 86-12v, 85-ground, 87-lo beam wire, an 30 would be your trigger to the ballast. But I feel you it's a bit aggravating but it's no biggie. I know it's got nothing to do with ddm as everyone at my shop an my gf all are using them with no issues.
Old Feb 4, 2011 | 06:40 AM
Gas Man's Avatar
L&L... try to increase your fuses to your headlights (low beam I think is all that is needed) by 5amps.
Here's the DDM troubleshooter
https://www.ddmtuning.com/support/in...d=1&parentid=0
Sometimes they can be funny acting but once you get the bugs worked out on your setup, you'll love em. I've been working with VJ over text messages the last couple days...
Old Feb 4, 2011 | 01:26 PM
ufvj217's Avatar
Screw the ddm troubleshooter. I use the gasman troubleshooter!
And ya L&L, try the fuse thing. Mine were fine after I pulled the drl, but then yesterday neither came on till i flickered with them on and off. I'm going to increase my low beam fuses +5a when I get home today.
Old Feb 4, 2011 | 02:09 PM
  #26
Low-n-Loud's Avatar
I'm gonna try that in just a minute. That would be great if that fixes it. If not o well, back to flickering them on/off once. Thanks gasman!
Old Feb 4, 2011 | 02:32 PM
  #27
ufvj217's Avatar
Gasman ftw!
I'm glad I'm not the only one with issues running 55w hi/low ddms. Not saying I'm glad you are too.. lol you know what I mean
Old Feb 4, 2011 | 08:25 PM
  #28
Gas Man's Avatar
So did it fix them VJ???
Old Feb 4, 2011 | 08:52 PM
  #29
ufvj217's Avatar
Ill know tomorrow :)
ufvj217
Dec 19, 2011 07:50 PM
ballplr
42
Oct 11, 2010 09:47 PM
RobsTurtleHHR
South East
Jun 27, 2009 11:29 AM
RobsTurtleHHR
0
Feb 23, 2009 08:01 PM
thunderstruck88
Jan 15, 2009 05:37 PM
