wheel bearings
Old Dec 8, 2012 | 10:01 AM
wmsburghhr's Avatar
Installing the axle nut too tight can cause premature hub failure. The Axle Nut torque spec is 155 5ft lbs and use a new nut
Old Dec 8, 2012 | 11:12 AM
Originally Posted by wmsburghhr
Installing the axle nut too tight can cause premature hub failure. The Axle Nut torque spec is 85ft lbs and use a new nut
Where did you get that spec for torque ?
Many different sources state 155 ft lbs on the drive axle hub nut.
Now the hub/bearing assembly mounting bolts take 85 ft lbs.
Old Dec 8, 2012 | 11:49 AM
wmsburghhr's Avatar
Sorry sleeper, I mis-read the manual and made the correction. Old retired eyes don't work like when I was a kid in the Triassic period of time.
Old Dec 8, 2012 | 04:01 PM
kingkat4's Avatar
We took the HHR to the shop because of front end noise and I figured bushings right away. But all he could find was the bearing.
My shop told me there is a 1 year replacement on the $250 bearings and none on the cheap ones. He said that the bearing he replaced was loose?
Maybe not proper torque the last time?
Later KK4
Old Jan 2, 2013 | 08:51 PM
kingkat4's Avatar
Update
Replaced the 6 month old wheelbearing no charge .
Noise is still there. Mechanic can't find what it is.
I guess we will live with it like others do.
Oh well.
thanks KK4
Old Jan 3, 2013 | 03:36 PM
check for threads on this subject, could be many things from sway bar links to lower control arm bushings to strut top bearing plates and so on
Old Jan 26, 2013 | 12:41 PM
The Old Guy's Avatar
Well I had the same problem on my 08 HHR.....the load roaring noise from the right front side. Today my stepson who is an Audi Tech replaced both bearing housings, the front rotors and pads and the upper strut bearings all for under $300.00. It feels like a new car!! Sure is nice to have a mechanic in the family!
oldloadie
Dec 25, 2014 09:51 AM
Franco Fanfuria
Drivetrain (Excluding Engine)
Oct 16, 2013 02:40 PM
tealhhr
Sep 12, 2011 06:12 PM
ryry4ya
Oct 25, 2007 06:50 AM
