Where do I start? Noisy, rough idle, poor performance, leaking oil
Old Nov 23, 2018 | 12:07 PM
Rand019200's Avatar
Hello all and thank you for helping. I just purchased thos 2006 HHR 2.4 and it ran okay for a couple weeks, but now is rattling so loudly I get stares while driving. Oil was. Hanged when I purchased it and I've had to add 2 quarts in less than 2 weeks. Codes are: C0561, P0011, P0101, P0128, P0171, P0014, P1174, P0366, P0326, P0300, P0137.
not sure where to begin. Any help would be appreciated.
Old Nov 23, 2018 | 01:27 PM
Hi Rand, to the forums!!
Codes or no codes, I would want to know if it is burning that much oil, or leaking it out. If it's leaking, that could probably be fixed relatively easily. If it's burning that much oil, it may not be worth fixing, a new (or used) engine may be the best bet.
Keep the oil topped up for now, checking daily, until this oil problem is figured out.
With that many codes, I would be having the battery load tested, post up the voltage/amperage results here.
Old Nov 23, 2018 | 02:46 PM
x2 what RJ said. How many miles on it?
You also need to figure out what is causing the rattling sound. The best and easiest way to check that out is to take it to a mechanic and let them figure it out. Trying to diagnose noises over the internet typically are a waste of time.
Driving it while it is rattling like you say, is not advisable. You can likely be causing further problems - and if the rattling is coming from the timing chain and it's tensioners, and they totally crap out while driving, you can kiss the motor goodbye.
Old Nov 23, 2018 | 05:09 PM
Most of the codes refer the timing issues, and thermostat, if the timing chain is stretched or a guide broken, it could cause some of these troubles, the oil leaking is a game changer, where and how much is it leaking, if it’s the harmonic balancer seal , bonus you should change that with the timing chain
so, I have to ask, how are you at spinning wrenches.
Old Nov 23, 2018 | 06:28 PM
My guess at the codes is a wire in the harness is broken/burned/frayed.
"rattling" means nothing to me. When,where etc? Needs adjectives.
Old Nov 23, 2018 | 06:36 PM
Yes a broken or loose ground or connections in the harness
tiggercross59
Sep 26, 2024 02:16 PM
Madmatt6988
Apr 28, 2013 01:42 PM
Tyler Harvey
23
Aug 15, 2011 12:15 PM
Willie Ditz
Nov 22, 2010 05:12 AM
plunger69
Mar 24, 2009 10:53 PM
