Wierd Noises
Wierd Noises
Hi, my mom's HHR has developed a couple of wired noises and I was wondering if any of you had experienced any of them. There is a noise in the headliner that sounds like something is fluttering. There is a noise in the rear hatch, right when you pull it up it makes a sound on the inside. Last, a noise in the front right wheel area, like a popping sound when at full right lock, but this has only happened once. Thanks in advance!
https://www.chevyhhr.net/forums/problems-service-repairs-42/front-end-noises-7170/
As far as the rear hatch noise, mine started to make a sound when the actuator had been replaced. Had only had Dory for 3 months at that time.
