Will not start
Old Jun 20, 2025 | 10:17 AM
Ronald Yeakley's Avatar
Check your work, make sure all electrical connectors have been reconnected. If still no change, start reinstalling the old parts one at a time. Some new part may have been bad.
That's probably the best piece of advice anybody's gave me so far I'm going to try it again I said if this scanner doesn't work here around noon
Old Jun 20, 2025 | 11:18 AM
So, you are just going to ignore any questions asked in order to figure out how to help?
I bet your timing chain broke but you won't clarify anything. The best advice is to help us help you by answering questions in some sort of coherent way.
Old Jun 20, 2025 | 11:46 AM
I'm sorry for not answering I am very busy on I have a detailing service I do so I get sidetracked sometimes the car I was told that has something to do with the fuel pressure I'm checking it out today and plus I'm getting a better scan or so I can let's see what happens from there I'm going if this doesn't work I'm going to take the timing chain I just didn't want to have to take the valve cover off start on that project cuz I've done so much money in this car so I believe me dry so I appreciate your feedback and I'll look right into that if it mind process doesn't work today thank you
Old Jun 20, 2025 | 12:42 PM
Re read post #4, please
Old Jun 20, 2025 | 04:48 PM
OK, so you had no reason to replace those parts, just decided to do it? None of the parts cited are wear parts, except the spark plugs. You wasted time and money if you preemptively replaced them.
If you are throwing parts at the car without troubleshooting you are just throwing money away.
And, don't believe anything you read on Reddit or Facebook.
Old Jun 20, 2025 | 07:01 PM
greg8453's Avatar
It's why I left this one.
Old Jun 21, 2025 | 08:15 AM
PulpFriction's Avatar
In case you missed it, #10.
Old Jun 26, 2025 | 11:02 PM
Today I got the water pump on I'm waiting on a new set of cans and I got the valve chain on when my cans get here and I can set the rest of it and I'll start putting it back together but I also found a cracked manifold a lot of little things too bad nothing you can tell the motor has three and 15,000 miles on it still has a beating heart and want me to get it back to going if it takes the last dollar I got
Old Jun 27, 2025 | 07:20 AM
I’m thinking you mean cams not cans! Cracked manifold is problematic. Dorman sells replacement.
Old Jun 27, 2025 | 06:41 PM
Cam problems
I have a le5 2.4 l engine it's in a 2010 Chevy HHR Lt with the automatic transmission when I was changing the timing sprockets on the intake cam it's spun because it was too tight I can't get it back to where it was Aton the cam what am I doing wrong or how do I go about the getting it back to where it was supposed to be I need a response quick cuz I'm trying to put it back together and I don't want it to be wrong when I go back to putting it back in the car any response would be good
