Window wiring schematic requests
Here:
2007locks.pdf
2007locks.pdf
thank you!
Fascinating! The unlock switch uses resistance regulation which is identified by the BCM to determine if lock or unlock is applied. low impedance = lock, high impedance = unlock.
Consider that this type of design has been used in other components for years, such as steering wheel radio controls. Super simple, one wire in, one wire out with multiple functional capability.
I will state that even if I find a switch that is not of the proper design, it would not be hard to add the stock button's resistor inline such that a standard style switch could accomplish this function.
wait.... could I skip a switch and make either front door rod be the control? pull or push to activate all other locks?? Discrete and unnoticable.
The ignition switch uses impedance, too. Why use wires when a resistor will do the job.
