Wobble and knocking in steering wheel
Old Jun 12, 2015 | 12:07 AM
Be aware that the lower control arms are available as a cast piece or in a fabricated steel design. The Cast one is for the HHR's - the fabricated steel ones are for Cobalts I think (but they will fit apparently). Stick with the cast ones. :)
here is a How-to article on replacing those lower control arms......
> https://www.chevyhhr.net/forums/how-...ol-arms-44378/
Old Jun 12, 2015 | 09:47 AM
Franco Fanfuria's Avatar
Awesome! Thanks for the info Whopper!
Old Jun 12, 2015 | 10:25 AM
The LCAs can be an easy job, I'd replace the sway bar bushings while the cradle is loose.
Old Jun 12, 2015 | 11:23 AM
Good point on replacing the sway bar bushings at the same time - they are a bit of a pain to replace, but why get your hands dirty twice. :)
FYI - a couple of people have had problems reinstalling the massive bolt that secures the rear of the LCA to the cradle/body, but hopefully it will go well for you. If you want to save big $'s you can just replace the bushings themselves (<~$20 ea.), but you pretty much need a press to do the re & re of them.
Old Jun 12, 2015 | 12:58 PM
I watched a YouTube video where the guy used two different sized hole saw blades and a length of threaded rod to press out old bushings and to push back in the new ones.
I used my air chisel to remove and a pair of sockets in the bench vice to press the new ones in.
Next time just new LCA's
donbrew
Dec 26, 2014 09:00 PM
capp002
Nov 17, 2010 03:42 PM
CDS31MC
Tires & Wheels
18
Oct 23, 2010 11:14 PM
andoll83
Jun 11, 2010 02:14 AM
