Yet another fuel smell thread
Old Sep 3, 2022 | 06:19 PM
McB_HHR's Avatar
Some time ago, there was an overfill situation. Ever since then, if tank is filled till pump auto clicks off there is a fuel smell. Otherwise, all is well. No codes, no drivability issues. Wife took over the car and I didn't say anything. CLICK.
Q: What is the most likely or common cause?
The goal is to limit the time spent outside messing with it due to heat. Its hot! That an I'm not getting younger. :) Not apposed to dropping the tank, but maybe that isn't the most likely cause. Would be a shame to do all that without replacing worn bits "while in there" but if it doesn't solve the issue then its a waste of time and money. This is a secondary vehicle with only real transport duty twice a week... REAL tempting to just keep the fuel level at 3/4 tank
Links for myself:
https://www.chevyhhr.net/forums/how-...t-44780/page2/
https://www.chevyhhr.net/forums/gene...k-64786/page3/
https://www.chevyhhr.net/forums/prob...k-63571/page3/
https://www.carparts.com/details/Che...C22719581.html
Old Sep 3, 2022 | 06:45 PM
I doubt you would have rusty fuel lines , but
https://www.chevyhhr.net/forums/how-...follies-62310/
Old Sep 3, 2022 | 09:13 PM
Lonwane's Avatar
I have the same issue until the fuel tank level drops below 3/4.
From what I've read the vent lines on top of the tank are prone to loose there seal.
Especially in hotter climates.
Old Sep 3, 2022 | 09:27 PM
If it started immediately after the overfill, my guess is some fuel spilled into the vent and contaminated the charcoal.
Old Sep 4, 2022 | 12:58 AM
McB_HHR's Avatar
In a odd way, I'm hoping for that. lol.
Old Sep 4, 2022 | 05:31 AM
PulpFriction's Avatar
No check engine light? No codes?
Old Sep 4, 2022 | 08:48 AM
McB_HHR's Avatar
Nothing. Zip. Zero.
Old Sep 4, 2022 | 09:25 AM
Fuel line wet just at the bottom of the insulation, above the front of the driver’s side rear tire?
JonArcherAZ
May 4, 2022 07:10 AM
carrzkiss
Maintenance and Upkeep
13
Mar 15, 2021 04:33 PM
bugo
Oct 17, 2015 01:02 AM
SindyDix
Aug 10, 2006 12:58 PM
