Fault P0016 Problems
Old Apr 25, 2018 | 07:01 PM
scratchy's Avatar
I have a 2008 2.2 non-vvt, has fault P0016, was told timing chain bad, replace timing chain set, still has fault. Then told need to change camshaft, replaced and still fault. Then changed cam and crank sensors and still has fault. Engine runs OK but maybe a little low on power. Any ideas what the problem could be?
Old Apr 25, 2018 | 07:46 PM
Hi scratchy, to the forums!
You probably should pull the valve cover and timing cover and recheck the timing. If you didn't know, you need to release the tensioner before you button it up. The chain may have slipped a tooth or more.
How poorly was it running before you changed the timing set?
Old Apr 25, 2018 | 07:52 PM
scratchy's Avatar
I have already done that and it is timed and tight. The problem started one day when i went to start it and it started and died, then didn't want to start. Finally started and ran bad. The chain was loose and had jumped.
Old Apr 25, 2018 | 09:00 PM
Did you properly torque the crankshaft balancer bolt?
Do you mean the CEL is on or that there is a history fault in memory. A history fault takes 40 cold starts to clear.
Old Apr 25, 2018 | 09:04 PM
scratchy's Avatar
CEL is on.
Old Apr 25, 2018 | 10:40 PM
Then either the balancer needs tightening or your chain is off a tooth or 2.
From the shop manual:
First pass to 74 lb.ft.
second pass to 125 DEGREES
Guessing the torque is not good enough.
Old Apr 29, 2018 | 07:23 PM
With the 2007 non VVT , I’ve had that P0016, it was the timing chain off one tooth. It’s kinda hard to assemble the cam gears and marks and look at the crankshaft gear marks.
Of course my OCD and how I’m positive it’s right cause I just lined it up.
Rjj
Oct 22, 2017 08:56 AM
Parker2636
7
Sep 9, 2017 08:22 AM
Al Chapman
Mar 19, 2014 08:38 AM
Josh4299
7
Jan 3, 2012 12:49 PM
geg
Jun 26, 2011 11:01 PM
