Upgrading the base unit
Old Jun 30, 2008 | 06:49 PM
wxman's Avatar
Hi, I am curious about a couple of issues with the stock basic stereo setup in the LS model. I haven't pulled back the rear panel to look, but would the wiring exist for the sub and amp if you don't have the premier system? There is a grill in the rear panel for a sub so I'm hoping there may be attachments and wiring in place for the sub as well?
I want to add an 8" sub in the side panel, replace at least the 2 front door speakers and add an amp to the factory head unit with minimal hassle. And, it has to be completely hidden/stock looking.
I'm not looking for a lot of bass, just good clean sound for my country music. :)
If most of the pieces are in place, I'll could try this myself. If I have to run new wiring, then I'll need an installer to do it. I'm not confident enough to start pulling carpet and whatnot.
Old Jun 30, 2008 | 07:05 PM
oneton's Avatar
No wiring. No anything
Old Jun 30, 2008 | 08:54 PM
djmoose's Avatar
oneton nailed it. If you don't have the premium system, no wiring...no enclosure...and a totally different car-side harness plug behind the radio.
Old Jun 30, 2008 | 10:35 PM
wxman's Avatar
I thought as much. Gonna cost me a bit more then....
The head unit will still take an amp, right? Or is this thing not worth the trouble?
Strikes4Days
14
Mar 26, 2015 05:33 PM
8thmileman
Jun 22, 2012 10:28 AM
TAK
0
May 10, 2012 07:53 PM
Stumpy Knucks
Jun 17, 2008 03:43 PM
riverwind
Aug 8, 2006 08:52 PM
