Adding factory amp and sub
Old May 4, 2011 | 06:51 PM
Robert617's Avatar
Hello guys I was needing to know I have a 2007 HHr and it did not come with the factory amp and sub that goes int he back But I found a new one and I was wondering can I add this like a plug and play or will I ned to run all the wires for it?
Old May 4, 2011 | 06:58 PM
wiring is not there
Old May 4, 2011 | 07:45 PM
otacon's Avatar
Originally Posted by GDZHHR
wiring is not there
Yeah I just took delivery of my 2011 HHR without the Pioneer system and I looked behind the panel in the back...noooo harness. Even if you order the harness from a dealership going from the head unit back, going to cost $$, you still might need some kind of control module according the parts manager I spoke with. All I'm looking for is to get signal to back so I can run a mono amp. I'm hoping the 'PAC AOEM-GM1416a GM Add an Amplifier Adapter' will do the trick.
Old May 4, 2011 | 10:45 PM
Robert617's Avatar
Thanks
Thanks a lot guys I think I will go with a infinity bass link powerd sub I use to have one ans it sounds awsome.
SouthLyonHHR
May 9, 2014 07:00 PM
xpmorin
Jun 11, 2012 10:09 AM
johouse05
Sep 14, 2010 09:58 PM
dfridge
Dec 21, 2007 07:37 PM
