2.0 5 speed engine R&R
Old May 11, 2020 | 01:16 PM
Kc0kfg's Avatar
Well it's time to get started on the SS
Now I know the factory way to drop the cradle,
and I've see guys pull the motor out of the top with an auto.
But with a manual isn't the flywheel and pressure plate going to make it really hard to remove fro. The top?
Let alone getting it back on the input shaft going In
Dropping the cradle is the best way yes?
Old May 11, 2020 | 01:27 PM
Easiest, anyway if you have a lift. Just disconnect the 4 cradle bolts and the 6 strut tower bolts (or pull the axles)(and other stuff) then lift the body off.
Old May 11, 2020 | 02:07 PM
I just recently completed this. Lowered the cradle, no lift. Make sure to read my post #56, shows the difference between the jacks that I used. https://www.chevyhhr.net/forums/prob...-engine-62561/
Here is fastsuv's thread that gave me the inspiration for the job. https://www.chevyhhr.net/forums/how-...ut-lift-57722/
fastsuv
Jun 21, 2017 07:48 AM
Bkm0607
Sep 13, 2012 02:39 PM
VictorySpark08
Mid Central
12
Jun 19, 2009 10:31 PM
Lone Ranger
Jul 21, 2008 08:01 AM
WickedHHRLT
Jan 24, 2007 11:29 PM
