Coolant Recovery tank looks empty!!!
Old Feb 27, 2011 | 12:18 AM
  #41
I put a mark on my rec tank that is very easy to see..
Winter it is a hair under the mark, but on warmer days it right on my mark..
It's a bit higher than stock fill. But not so much that it would ever overflow in summer etc..
Old Feb 27, 2011 | 05:41 PM
  #42
hurst2001's Avatar
update i found the source were it was leaking after i filled the bottle up it was leaking were you fill the radiator tee part were the cap goes on under were the seam meets you can feel it bowed like were the seam meets..I mean the whole tee is plastic like you would buy from prestone to do a flush ,you chevy should at lease made that part out of aluminum,well is this a dealer part to order or can i find it somewhere else ?
Old Feb 27, 2011 | 11:28 PM
  #43
chudlychudson's Avatar
Mine had the radiator hose rub through and leaking where it touched the manifold to brake booster vacuum hose. They replaced the radiator hose, and covered it with a corrugated plastic cover.
Old Mar 7, 2022 | 08:46 PM
  #44
Originally Posted by sleeper
02-27-2011 01:18 AM I put a mark on my rec tank that is very easy to see..
Mine is still fine this way.
HHRnovice
Dec 15, 2016 08:46 AM
slonny
Nov 7, 2016 06:30 AM
ChevyGirl
Apr 6, 2012 02:39 AM
REDHHRSS
Jun 3, 2009 09:24 PM
denny
Dec 26, 2006 09:04 PM
